メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Flip 5は、2019年8月に発売された小型のポータブルBluetoothスピーカーです。IPX7の防水性能を備え、最大12時間のバッテリー駆動時間を実現しています。モデル:TT
Turns on for a second, then shuts off
The speaker turns on, makes the power up sound, but only the battery level indicator lights up, showing 90% charged. But the power button doesn’t light up, nor does the Bluetooth button. The battery light goes out, but when I press the bt button it lights up again for a couple seconds, but no bt light, and it doesn’t show up on any device I’ve tried, nor the app. I’ve tried all the reset options and the service mode process, but no luck. Party chain lights don’t seem to work either. Please help….
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Well, actually ended up taking it apart, thinking it was broken anyway! Find that the connecter to the top 4 buttons to the main board had some corrosion on the cable so I tried cleaning those up a little bit. I had to snip the ribbon cable tip off just a little bit but Putting it all back together. I accidentally ripped the ribbon cable at the connecter. so I thought, “well I’ll just try to shave a little bit of the casing off..” using a metal blade I must have completed the power circuit cause it turned on! I kept going and sure enough, pairing mode triggered and I connected to my phone and works like normal! Even tho the power/bt buttons aren’t connected! Lol know where to get a replacement ribbon cable?!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@toddlum the very first thing I would do is to replace the battery. Remember that the battery indicator may say 90% charged but your battery may no longer hold a complete charge.Try a new battery and then re-evaluate. JBL Flip 5のバッテリー交換
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Todd Chapman さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 30
過去 30 日: 142
今までの合計 2,661
