My xbox one s doesn't start
My game doesn't turn on
Sounds like the motherboard or power supply. Replacing the power supply is the first and easy step, if that didn’t worked, then return it and get yourself a refund. Then you do need to check the motherboard..
このアンサーは役に立ちましたか?
Thankyou brother <3
My pleasure! Good luck with the repair!
Mi consola desde una semana no prende y se queda en negro la pantalla y cuando la prendo mi consola requina
このアンサーは役に立ちましたか?
My x box don't turn on
このアンサーは役に立ちましたか?
Please see my anwser above, would try that first. Thank you!
過去 24時間: 4
過去 7 日: 14
過去 30 日: 78
今までの合計 1,587
6 件のコメント
Hi! We do need more information at the moment. Is the Xbox not booting up or are you unable to play games on it? If games related, do downloaded games work fine? When it's Xbox related, it could be the hard drive which failed. Please show us a video regarding the issue so we can help you further. Thanks!
koppie007 さんによる
Same problem mine not booting, when I press the Xbox logo button nothing happens 😵💫
Hassan Khan さんによる
Does it turn on with the controller?
koppie007 さんによる
Noo, I last played a week ago but now it's not starting
Hassan Khan さんによる
My xbox turns on, it works fine, you can watch yt or use any other app smoothly, but whenever I open a game, the xbox turns off, it shuts down.
Zaid Ahmed さんによる
1以上のコメントを表示
