HP Pavilion tar imot lading KUN med lukket skjerm
Det er ikke lenger mulig å lade min HP Pavilion laptop med åpen skjerm. Lading er kun mulig når skjermen er lukket.
Når strømkabel plugges inn i pc med åpen skjerm, vises ladesymbol ca 10 sekunder før det forsvinner.
Når skjerm er lukket, lyser ladelampen kontinuerlig og pc kan lades opp til 100%
Google translate:
HP Pavilion accepts charging ONLY with screen closed
It is no longer possible to charge my HP Pavilion laptop with the screen open. Charging is only possible when the screen is closed. When the power cable is plugged into the PC with the screen open, the charging symbol appears for about 10 seconds before it disappears.
When the screen is closed, the charging light lights up continuously and the PC can be charged up to 100%
Hi @mariannesteine
What is the model number of the laptop as shown on the product information label on the bottom of the laptop?
Can you connect an external monitor (TV?) to the laptop and view the display from the laptop on it (with no display showing on the laptop screen) and successfully charge the battery at the same time?
jayeff さんによる
