メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
634回答 すべてを表示
Screen Flickering - Going dark at the edges - Then No Power
Macbook Air 13" A1355 2015 Model Arrived......Turned it on.... after a few seconds the screen began intermittent flickering and then shadowing in one corner at a time.... Shut it down, disconnected the battery and reset SMC that way, disconnected then reconnected the LCD connector, reset PRAM, then restarted to the same issue.... shutdown... power up and it is totally dead, no fan spin, zero. Internals look very clean, no signs of previous repair (Is from a friend who said all was working fine beforehand). Just my luck again! What on earth could have happened? @danj and @oldturkey03 to confirm that everything is totaled shot.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
What happens when you plug in an external display?
Do you have a spare battery for this system? See if that helps.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@danj It has a good battery and I did try another, there is no difference.
It don't boot up, dead, no fan spin, zero.... I did not try booting with an external display as it don't boot up..... I tried without battery and hot pads..... logic board again.... It is so odd, I always ground myself, use rubber gloves, didn't touch any board parts only th battery and screen connector to see if they had come lose.... anyway I have returned the unit to the previous owner.
さんによる
コメントを追加
回答を追加する
livfe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 8
今までの合計 30
