メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PS4、PC、モバイル端末で使用できるサードパーティ製ワイヤレスコントローラーです。
Why it's not charging when I plug it?
why it's not charging when i plug it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
1 件の回答
最も参考になった回答
Hi Yusme, I hope your having a great day!! Let's have a look on your problem. It looks like your RIPPA RA903B Controller is not working.
You can do some simple stuff to get your problem fixed if its not a major one:
1.) Check the Charging Cable and Port
  • Ensure that the Micro USB charging cable you’re using is in good condition and properly connected to both the controller and a power source (such as a USB port on your computer or a wall adapter).
  • Inspect the Micro USB port on the controller for any damage or debris. If there’s dirt or lint inside the port, gently clean it using a soft brush or compressed air.
2.)Reset the Controller:
  • Sometimes a simple reset can resolve charging issues. Try the following:
    • Hold down the reset button (usually a small pinhole near the L2 trigger) for a few seconds.
    • Reconnect the controller to your device and check if it starts charging.
  • Check the Battery Level Indicator:
    • When you connect the controller to a power source, look for any LED indicators that show the battery status. If the controller is completely discharged, it might take a few minutes before any lights appear.
    • If you see a red light, it means the controller is charging. Let it charge until the red light turns off.
    • If you see a green light, it indicates that the controller is fully charged.
  • Try a Different Charging Source:
    • Test the controller with a different charging source (e.g., a different USB port or wall adapter). Sometimes the issue could be with the power source.
  • Hard Reset:
    • If none of the above steps work, try a hard reset:
      • Hold down the PS button (the PlayStation logo button) and the Share button simultaneously for about 10 seconds.
      • Release the buttons and then reconnect the controller to your device.
  • Firmware Update:
    • Check if there’s a firmware update available for your controller. Visit the manufacturer’s website or search for any official updates related to the RIPPA RA903B Controller.
Remember that third-party controllers may have varying compatibility and charging behaviors. If you’ve tried all the steps above and the issue persists, consider reaching out to the manufacturer’s support or checking community forums for specific solutions related to this controller model.
Additionally, I found a teardown guide for the Rippa RA903B Controller. It provides detailed instructions on opening the controller, which might be helpful if you need to inspect the internal components. However, proceed with caution and only attempt this if you’re comfortable with disassembling electronics.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
回答を追加する
Yusme Yusof さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 42
今までの合計 1,586
