Charging but won't turn on
when I use the battery from 17 inch to 15 inch after 2 weeks suddenly shut down, only when I plugged in is green and also charging the battery , I have tried to find a defect component but I couldn't found
So I have a diesel car will gasoline work instead? I hope you don't try that!
Just because the batteries share similar connections and the voltages are the same the current it offers as well as what it takes to charge is not the same. The 17" battery is more powerful than the 15" as such it can overload the logic board logic.
Please you the correct battery for the system, at this point the logic board likely needs repairs in addition.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 34
15" A1286 2012 use a 75 W h Li-Poly Battery
17" A1297 2009-2011 use 95 W h Li-Poly Batteries
Does a 17" Models battery fit in a 15" ?
They look completly different
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery
MacBook Pro 17インチ Unibody バッテリーの交換
livfe さんによる
Try it without a battery connected, If it still won't boot up then it is very highly likely the logic board has been affected by the voltage overload from the incorrect and more powerful battery that was wrongly used.
livfe さんによる
I have tried to find the defect component via board view but I’m not sure which component is defective I have also measured components but Im not sure
ali ariai さんによる
@aliariai as previously suggested "Try it without a battery connected". Let us know what happens.
oldturkey03 さんによる
I have tried to disconnect battery and then I held power button for 15 second and then I plugged in in same time and then fans moves very fast and I pressed power button to off but still no turn on
ali ariai さんによる
