メインコンテンツにスキップ
2015年10月13日に発売。A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 プロセッサ。
97回答 すべてを表示
Bluetooth devices are disconnecting
I have a 21.5in iMac (2015) running Monterey 12.7.2. It randomly disconnects from all bluetooth devices. I have attempted to reset the bluetooth by deleting the plist data and reseting the bluetooth module. I have checked to see if the bluetooth devices that disconnect work on my MBP and they do without issue. Is there any solution to fixing my iMac?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Do you share BT devices between your systems? I found some devices tend to gravitate to a given system even when you don't want them to. Make sure to keep the BT devices you don't want connected as well as other systems as far as you can. See if that makes a difference.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Would having AirPods that connect and disconnect frequently have anything to do with what you're referring to?
さんによる
@brandonstewart - If they are used between the two systems.
さんによる
コメントを追加
回答を追加する
Brandon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 26
