メインコンテンツにスキップ
2020年11月に発売される13インチMacBook Airは、AppleのArmベースのM1 SoCを搭載し、8コアのCPUと最大8コアのGPUを搭載しています。(モデルA2337 / EMC 3598、Thunderbolt 3ポートを2つ搭載)
181回答 すべてを表示
MacBook is not turning on?
Hey Guys,
Got given an M1 MacBook Air by work as it wouldn’t turn on and was just wondering if anyone had any advice to test and see if it was indeed fully dead?
Tried charging it for a bit and got nothing, including no sound from the speaker or light from the caps lock key. Put it back in the box afterwards, which was a month go, and am doing a clean out so would love to get it working!
Thanks (:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Dead as a door nail systems are always tricky! The newer MacBook Pro systems at least offered a MagSafe port so you could see if there is even power getting in.
With the Airs it’s tougher as we need to use an inline power meter to see the power MakerHawk USB-C power meter. With it you should be able to see if the system is even charging.
Do you know any of the history of this system why is was not working back then? As it could be as simple as needing a new battery or more complex issue where the systems logic board is bad.
We still have one more obstacle! As the person who gave you the system will need to release it from their iCloud account as the systems security needs to be cleared. That also means you need to have the system able to phone home to get the message it’s alright to work for the next owner.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi TmG
I would advise you to first attempt to boot it up in recovery mode.
For more info, see here:https://support.apple.com/en-ca/102575
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
disregard this, just follow Dans solution first, then do mine just in case.
さんによる
コメントを追加
回答を追加する
TmG さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 32
今までの合計 32
