メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
My mid-2012 MacBook Pro graphic glitches
Just today I was using my mid-2012 MacBook Pro and it started to have graphic glitches. When the computer been running for awhile it will have these box glitches all over the screen and the computer stops working. Is this a logicboard issue or does it need new thermal paste?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You’ll need to do a bit more diagnostics to help aim you to what’s needed. I would install a good thermal monitoring App like TG Pro it will allow you to see more clearly the CPUs & GPUs heat levels as well as the efficiency of the heat sink and heat extraction via the fan.
So when the glitches show up what was the systems thermals? If you boost the fans RPM does that help?
You might find the heat sink it’s self has failed (the coolant had leaked out) and/or the thermal paste needs to be refreshed.
The second test is when you encounter the glitches to plug in an external display to see if the image on it is stable. As sometimes the display unit fails.
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
On the TG app it say CPU core 1 is 113 F and core 2 is 109 F. Gpu is 120 F and heat pipe is 87 F and right heat sink is 100 F.
さんによる
On the TG app it say CPU core 1 is 127 F and core 2 is 131 F. Gpu is 139 F and heat pipe is 92 F and right heat sink is 106 F. When in use of appliances.
さんによる
On the TG app it say CPU core 1 is 147 F and core 2 is 149 F. Gpu is 155 F and heat pipe is 107 F and right heat sink is 119 F.
さんによる
@nickwood16080 - Sadly I really need a snapshot of the Apps main window with all of the sensors visible. One snap when the glitch happens and one after the glitch subsides. Post both here so we can see.
さんによる
I think I fix the problem I took the logicboard out and cleaned it there was a lot of dust inside. And added new thermal paste on to the CPU or GPU. Put it back together and now it wont power on with its own battery power it has to be plugged in to power it in. How do I fix that? I think it’s the keyboard ribbon cable that’s not plugged in that’s causing that problem.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Nick Wood さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 48
今までの合計 48
