Phone doesn't charge on USB-C
I tried different cables & chargers combinations. The phone doesn't charge.
I suspect the USB-C port. treid to clean it with a plastic tooth tip & air. Is it possible to replace the port?
Hi Kiilo,
while it is hard, it's possible to replace your phone's charging port. I'd advise you to watch this video for it. There isn't any for your exact model, but I'd say this is close enough to work:
このアンサーは役に立ちましたか?
@kiilo your Motorola is a XT2153-1. Slightly different then the previous model shown. Use something like this video since iFixit does not yet a guide for that. The charging board is readily available at many online places for not a lot of money.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
過去 24時間: 4
過去 7 日: 10
過去 30 日: 48
今までの合計 898
