My purifer unable to fill water in its tank?...why?
Likely calcium build up in the lines.
If you can, push a straightened metal coat hanger thru the fittings and pipes or use a calcium cleaner within a bucket to soak the fittings and pipes. Make sure to fully rinse off the cleaner from the parts and let the water run a bit before using.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 39
@sehajarora80537 let us know if you have a make and a model for this. You also want to post some pictures of your setup. Let's see what you got going on there. iFixitでの質問に画像を追加する方法
Mine uses a prefilter that require frequent changing. I clean mine every 3 months of use with food grade citric acid.
oldturkey03 さんによる
