メインコンテンツにスキップ
1985年に任天堂株式会社から北米で発売されたゲームコンソールで、Nintendo Entertainment System、モデルNES-001と呼ばれるものです。
Flashing Red NES Screen, new pins already, help please?
I've tried fixing two NES now, one with a solid grey screen, one with a flashing red screen, both have new pins and I have disabled the lockout chip on both. The games are clean and in working order but I can't seem to get any of them to work. Any help would be helpful. <---Redundant sentence! Yay!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
ベストアンサー
Give this a try. What I did was place two pieces of double-sided tape (stacked on top of each other amounting to about 2cm) while only removing one of the sides to both sides of the loading dock. So far it has loaded 5/5 games I've tried the first time without any hassle.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Forget all that he said^^^
I recommend u try taking a Qtip and some rubbing alcohol and running it along the teeth of the game (maybe open it to get full coverage). Then test it and email me if it's still not working.
さんによる
Yeah, forget what I said and suggest alochol? Don't you think that if he went through the trouble of opening up the console and installing a new pin header that he would have already done that? As did I. And it didn't work, that's why I suggested what worked for me on two different consoles and low and behold it is STILL working. But yeah, disregard that because this guy is a genius.
さんによる
The double sided tape is the way to go. I found that if I insert a game all the way it will not register. However, if I pull the cartridge back ever so slightly, it will play like a champ. So placing the double sided tape as shown by "Androxilogin", holds the cartridge back in just the right spot. I am not sure if this is due to my 72 pin connector being worn or what, but it works.
さんによる
I don't understand the purpose of the tape. Is it isolating the cartridge from possible grounding? Positioning the cart is so that it has full pin contact?
さんによる
I think that a part of the OP's sentence missing confusing.
さんによる
コメントを追加
Hmm interesting, I too have repaired many NES systems but the only thing I can think of that is causing this is a connection problem. What type of connection are you using to connect to your TV? I recommend a composite video cable, you can grab one for a buck on ebay. Other then that I would reccomend you take your NES apart make sure the 74 pin connector is solidly connected. I buy all my stuff from Nintendo repair shop, they have quality parts and they also have stuff to clean your games. So far I have not had a NES system or game that does not work. Way to go Nintendo for building solid machines.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I've been using an original coaxial cable, I will give the composites a try when I find the time, hopefully soon. Ill let ya know if it helps.
さんによる
コメントを追加
I replaced a 72 pin connector, purchased from Culsoms Original NES on ebay. I had tried to clean the old one with peroxide. I also tried a fine grit sand paper (suggested on youtube) With the new pin, I got a solid purple screen with one game and a flashing purple screen with another game. These are my only two games (mario bros/duck hunt and mario bros 3) Suggestions?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Nintendo Repair shop sells a two step cleaner system for game cartridges that I would really recommend you try. Your 72 pin connector may be fine but your games may have gunk or corrosion on the connectors. I really don't recommend using peroxide or sand paper on the 72 pin connector. In my experience once a 72 pin connector is shot it isn't because of corrosion it is because the metal has worn out and it is not making contact with the game because it has lost is spring to make a solid connection.
Don't use games that have not been cleaned on a new 72 pin connector.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
what is a 72pin thingy
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The 72 pin connector is what makes contact with your game cartridge inside of the NES system. They get worn out and can be easily replaced. They cost around $10 on ebay.
さんによる
thanks! iamtypingstuffbeacuseoftheminimumoftwelvecharacterslolilikethenes
さんによる
コメントを追加
回答を追加する
james さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 41
今までの合計 14,463
