メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
How do I fit my replacement screen into a slightly warped frame?
I'm currently 95% of the way through replacing the screen of my old iPhone 6s. The screen is functional, but I'm running into a slight mismatch between the frame of the case and the screen, possibly due to the frame being slightly out of shape (upper left hand corner is the culprit, from the looks of it). I'm able to lower the screen into the frame, but as I do so, a small gap forms at the top which causes the bottom part of the screen to sit slightly outside the bottom of the frame, preventing it from completely lowering into place. Is there a way that I can (as a novice) shape the frame so that the screen can be placed in correctly / is there a special tool that would help me do so? Thanks for your input!
Edit: pics for reference
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
replace the housing, they arent that expensive
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Orobor0s さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 13
