メインコンテンツにスキップ
モデル番号A1286、発売日 2011年2月/2.0, 2.2もしくは2.3 GHzクアッドコアIntel Core i7プロセッサ
589回答 すべてを表示
Troubles with new battery
I have changed the battery for a new one, but it does not charge 100%. The charge remains at 99% and does not reach 100% so I cannot calibrate the battery. The magsafe connector gets quite hot. So I don't know if it's a problem.
I use WATTS to see the health of the battery, but it shows me values as if it were the old one, except battery charge at 99%.
I followed the battery replacement guide, so I don't know what could be wrong.
Update (04/05/24)
Here are from 3 differents are the same results with differents programs
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Let’s use a better tool, I find this one is quite good CoconutBattery take a snapshot of the Apps main window posing it here so we can see.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@andresmend79046 - Well the replacement battery is not healthy either! I would recommend you return it to get another or your money back. Its likely this battery is a remanufactured one where someone took the cells apart check the discrete cells and then put the better ones back together to create a new battery. What does the battery info button tell you for the deeper battery maker info?
さんによる
コメントを追加
回答を追加する
Andres Mendoza さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 35
