メインコンテンツにスキップ
2018年7月に発売された、モデル番号{A1989 / EMC3214}のMacBook Pro13インチモデルにはクアッドコアi5と i7 を搭載しており、グラフィックにIntel Iris Plusが統合されています。
208回答 すべてを表示
Purple & red flickering lines on 13in 2018 Intel MacBook Pro
Looking for suggestions and potential fixes. I have an Intel Macbook Pro 13-inch, 2018, Four Thunderbolt 3 Ports.
I unfortunately can't show you what it looks like since it's just in the display, but it's 5 columns of dashed lines of purple and red. I see some blue too. It kind of pulses on the screen.
Here is what I've tried to do so far:
  • Already reset the NVRAM and SMC - didn’t fix it
  • The temperature of the Macbook is fine (around 50º C)
  • Put it in Safe Mode and lines are still there
  • Ran Apple Diagnostics and it said no issues found
  • Also took a screenshot, and the lines don't show up, so it’s a display problem
  • My Mac is already up to date (Sonoma) so no graphics card driver to update
It does say Service Recommended for my battery but I think it's been like that. These lines interestingly showed up after using a 7 day trial for the app Iris (protects your eyes). Turns the screen red at night for better sleep. Not sure if that had to do with it.
I think there might be something loose with the display cable (?) but I can't find a youtube video with my particular model. I'm not sure if this can be fixed myself. The last digits of the laptop serial number is JHC8. Let me know if you need more info!
My coverage/warranty has expired.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sadly, the display assembly will need to be replaced. The lines are caused by shorting within the panels lines. There is nothing you can fix besides replacing the assembly. Here’s the needed part MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly and here’s the guide to put in on MacBook Pro 13インチ Touch Bar 2018 スクリーンの交換
MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assemblyの画像
製品
$479.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Okay, thank you very much! I'm willing to go for it. Do you happen to know how much it would cost Apple or Geek Squad to fix something like this? Just wondering for comparison.
さんによる
@maria28747 - The cost of labor is around $80 USD
さんによる
コメントを追加
回答を追加する
Maria さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 42
