My spacebar wont go back in
i took of my spacebar to clean some mess from underneath and i think something may have broke.
also if something is broken can you possibly tell me a way to fix or the part i will have to buy to fix.
thanks
Be careful here! Looking at your images I see the metal frame clips on the left side are bent to the side. They will need straightening but if you snap off the clips that will require a full keyboard replacement which you really don't want to do $$$.
You are also missing the spring wire that rides in the channels and clips into the frame as well. You'll need to contact these folks as the part listing they have doesn't list it TheBookYard UK: Space Bar MacBook Pro/Air (Type-R)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 39
