メインコンテンツにスキップ
Repair guides and support for your LG TV.
1345回答 すべてを表示
The screen is black and no sound
LG 32LH70YR
I have the same model with the same problem; the screen is black and no sound the led of front power button is on but the TV is almost dead? I tried unplug and re-plug after a while but the problem still exist; no picture and no sound. I think it is a power problem because we have unstability in the electricity.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@saiddahroug you have not told us what you have checked. The no video issue can be related to a bad backlight inverter circuitry. A simple check for that would be to darken the room and turn the TV on. Then use a flashlight and angle the light at the screen on different areas. you might make out some shadows or see s slight grey color.
After that, remove the back cover and take a look at all the boards to check for any obviously missing or damaged looking components. Take a couple of well focused pictures of the boards and post this with your Question. That way we can see what you see.
You will need a voltmeter to check a few things once we can see your boards. We need to determine if your main board tells your power board to turn certain circuits on. For now the prime suspects (in order of possibility ;-) are backlight strips. main board, power board, T-con board (if separate from main board) and the panel.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Said DAhroug さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 17
