メインコンテンツにスキップ
モデル番号はA1708/EMC 3164。2017年6月発売。このエントリーレベルのMacBook Proには伝統的なFunction Keyが搭載されています(OLED Touch Barの反対)。
569回答 すべてを表示
External case for SSD from a MacBook Pro 13" 2017 (A1708)?
A friend has an SSD that was removed from a mid-2017 13" MacBook Pro whose logic board died. She bought a newer MacBook Pro, so the 2017 is still nonfunctional. The SSD has data she needs to get. Does anybody offer an external case where this SSD could be installed? "These drives use a proprietary Apple PCIe 3.0 x4 interface with a 22+34 pin connector." (I'm still on a 2014 MacBook Pro, so these newer ones are unfamiliar territory.)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
I haven't been able to find any enclosures for this model SSD online. If any one else can find something, please comment here because I have also been looking for something like this. For now, the only way I've been able to access data on those drives is by installing them internally in a compatible functional MacBook Pro, which isn't an option for most people. Best of luck!
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Yep, that seems to be the situation. You might find this response of interest: https://discussions.apple.com/thread/255....
さんによる
Actually, this might be a solution! Just found this: https://eshop.macsales.com/item/OWC/S3DA...
さんによる
Nevermind, that's not an enclosure for the blade drive, it's just an included 1 TB external drive to help with data transfer :(
さんによる
コメントを追加
Sadly, no one offers the needed case, there is too little demand.
The only answer is to find either a 2016 or 2017 Fn system which is working sapping out the drive to gain access to the files. I would then use Target Disk Mode to transfer the apps and data over.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
HandyMac さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 22
今までの合計 92
