coffee does not flow into the carafe
brewed coffee stays in the filter basket and does not flow into the carafe
I don't know this devices, I can only give some general advices:
I wish you success!
このアンサーは役に立ちましたか?
Hello ccoffee! It may be because your coffee maker is clogged, and is unable to send any coffee into the pot. You can use a piece of wire to clean, or you can, if possible, wash it out. I hope this fixed your problem! - Gilchrist Dean
このアンサーは役に立ちましたか?
thanks but no not the problem coffee maker is brand new and i have washed it out after each use only 3 times used
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 61
3 件のコメント
@ccoffee can you verify that your coffeemaker is a Cuisinart DCC-1200?
oldturkey03 さんによる
it is a dcc3200 cuisinart coffee maker.
ccoffee さんによる
@ccoffee let's see if the ifixit coffeemaker Guru @vauweh has any ideas on this new machine.
oldturkey03 さんによる
