screen cover can't close
Top cover detaching so can close
Hi @jefftabs
Here's the hardware maintenance manual for the laptop.
Go to p.56 to view the procedure to remove/replace the LCD unit.
This should allow you to find out what the problem is regarding the lid cover coming loose.
If for example it is a faulty cover or hinge perhaps, on p.70 you'll find the part numbers for the various components in the lid.
If you meant the upper case assembly go to p.54. The upper case part numbers are on p.66. Note that the upper case includes the keyboard which is country specific i.e. country code is shown in part's description, if the whole assembly needs replacing etc.
If a part is faulty and needs replacing, search online for the part number only (FRU number) of the required part, to find suppliers that suit you best.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 24
今までの合計 302
1件のコメント
@jefftabs, We'll need a whole lot more information on the problem if you expect a helpful answer from the forum. Please revise your question to maximize community understanding.
Russell Repairs さんによる
