メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
9月20日に発売された、Appleのメインストリームとなる2019年iPhoneモデルには、6.1インチLCDタッチスクリーン、デュアルカメラが搭載されており、6色から選べるカラーセレクションです。iPhone XRの継続モデル。
iPhone 11 LCD replacement in progress
I ordered and received a complete LCD assembly and also the blue adhesive to repair my broken LCD. I've disconnected the old part and everything is so far so good. The LCD I've received came with what looks like the adhesive to waterproof the phone again, but is pink instead of blue, and I'm just wondering if there is a difference between the two. Do I use both, or one or the other? Thanks in advance for any help in clearing this up for me.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I'm doing the same but my y000 bit is to big and I don't know what I should do.
さんによる
@davidcrosb31239 Go for a Y0000, they're the smallest I know of and the smallest I have in my collection, they're sold on the iFixit Shop or through other retailers such as Amazon
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hey, @isaiahstallings
I would suggest you use the pink adhesive to secure the device, as it was intended specifically for this device, while the other may not be exactly what's necessary. At the end of the day, I don't believe the adhesive will make a difference, but just play it on the safe side and use the adhesive that was shipped with the LCD Assembly.
Pages of Interest:
iFixit Guide to iPhone 11 Display Panel Replacement
Additional YouTube Guide on usage of Display Panel Adhesive with iPhone models
iFixit Guide to Display Panel Adhesive Replacement
Good Luck.
iPhone ディスプレイ用接着剤の画像
ガイド
iPhoneディスプレイ用接着剤の交換
難易度:
中レベル
1 hour
iPhone 11 ディスプレイパネルの画像
ガイド
iPhone 11 ディスプレイパネルの交換
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Appreciate the help, I'm confident in what I'm doing again XD. What makes you say it makes no difference tho, because that is unfortunate. if thats the case why am I wasting my time with it?
さんによる
@isaiahstallings Most adhesives use similar if not the same ingredients, and stick just about the same. If i were you, I wouldn't use an adhesive compound other than the one provided, as it may not work as intended with the intended device. To answer your final question there, I'm not sure why you're wasting your time, money, or energy on even looking in the direction of the blue adhesive, as the pink one should be sufficient for this project.
さんによる
Thanks for taking the time to respond and for clearing up a few things for me, I appreciate you
さんによる
@isaiahstallings Yeah no problem man. If you wouldn't mind marking the question as answered so we get closer to answering all of em that would be great
さんによる
コメントを追加
回答を追加する
Isaiah Stallings さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 185
