How do I replace the keyboard of my MacBook Pro
I want to replace the keyboard of my macbook pro
Sadly, Apple makes keyboard replacement extremely hard! Most likely the heaviest used part of the system shouldn’t be this difficult to replace!
You literally need to tear it out with brute force. You see they use plastic rivets close to a hundred, then you need besides the correct keyboard and a pile of special screws replacing the rivets.
Given all of the work it’s just better in the long run replacing the full assembly MacBook Pro 15" Retina (Mid 2018-2019) Upper Case Assembly and as this is now over four years the battery likely needs replacing too. If you are a gambler and able to take the battery out without damaging it you could use this instead MacBook Pro 15" Retina (Mid 2018-2019) Upper Case while being a bit cheaper the expense of getting a fresh battery as well soon makes this more expensive.
Ok, what do I need to do to replace the keyboard? You’ll need to follow this guide as it will get you halfway there MacBook Pro 15" Touch Bar 2018 バッテリーの交換方法
There are quite a few keyboard layouts depending on your language choice. So make sure you order the correct uppercase or discrete keyboard if you go that route.
製品
$449.99
製品
$299.99
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 17
