メインコンテンツにスキップ
2018 MacBook Airのマイナーなリフレッシュモデルです。モデル番号 (A1932) とEMC番号 (3184)が2018年モデルと同じです。このモデルはTrueToneディスプレイと僅かにアップグレードされたバッテリーを搭載しています。
Randomly crashes and restarts
Hi yall,
I recently bought an used MacBook Air 2019, but it keeps crashing over and over again.
It happens randomly... after 5 minutes, after 10 minutes, instantly... unpredictable
Shutdown case is -20
Panicked task: pid49: bridgeaudiod
CORE 0 is the one that panicked.
SMC reset didnt work...
NVRAM reset didnt work...
Disk wipe and MacOS reinstallation didnt work either...
Guess its a hardware problem. SMC maybe?
Hope you can help me!
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I'm suspecting the issue is the MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard and here's the guide to get to it MacBook Air 13インチ Retina Display 2019 オーディボードの交換
While it doesn't look active it is! there is a small chip on the back side which is like;y failed or the has received liquid damage.
Replace a corroded, dirty, or damaged headphone jack by swapping in an audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.の画像
製品
$59.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hey, first of all thanks for your answer! So the left speaker is working, but the right one isnt. So there might be an issue with that. Do you maybe have an idea how the faulty chip is called so I can order a new one? I dont want to replace the whole board.
And why does it instantly throw a kernel panic? And why so unpredictable? i dont think, that speaker are so essential so throw a kernel panic
さんによる
@renax - The audio IC is a bonded chip on the back side its not replaceable on its own, you'll need to get the board assembly.
The I/O channel is shorting out some how is why the OS messes up which is the Panic call.
さんによる
コメントを追加
回答を追加する
Renaxツ さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 169
