メインコンテンツにスキップ
2022年2月25日に発売されたValve製の携帯ゲーム機「Steam Deck」の修理・分解・トラブルシューティング情報です。型番1010で識別されます。
253回答 すべてを表示
How to clean the inside components of my steam deck safely?
HI!
I was wondering how I can clean the inside of my steam deck, I never done this before and since I usually use my deck in a very dusty outdoor business, the inside of my steam deck is very dirty.
Thank you in advance for the help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @milanorwolf
Here's the ifixit Steam Deck repair guide that will help.
It details how to open the console and remove all the parts.
The first thing that you should do when you start is to make sure that you have a clean work bench and are organized having the correct tools to do the work and enough containers etc to place in any components that you remove, especially any screws etc. so as not to lose them
After opening the console, first disconnect the battery as soon as it can be accessed so as to nullify any electrical problems from occurring when working inside the console. Mechanical damage .e. tools slipping etc is another matter so be careful and concentrate on what you're doing.
Wearing a wrist strap connected to an earth point will also minimize any potential for ESD damage to the sensitive electronic components on the board if you happen to accidentally touch them.
To clean off the dust etc, use a soft brush and gently brush it loose and then use a vacuum cleaner (lowest setting) to remove it from the boards etc.
When finished reconnect the battery just before closing the case for the last time.
If you strike problems, stop and think about it first instead of rushing headlong into trying to solve it as you may cause unnecessary damage. This forum is full of questions from users who tore cables, broke plug latches, stripped screws etc most probably due to impatience more than anything else.
Slow and steady and I'm sure that you'll be OK.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Milanor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 18
今までの合計 50
