メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
I cracked screen. Not charging or green light on screen.
I dropped my Mac book Pro A1502 late 2013 and the screen cracked. At first there was power but blurry/lines on screen. Then the battery went dead and now will not charge. There is no green light on power cord. Bought a new power cord but still nothing. I’ve opened it up and when I attach the power cable the fan turns on for a few seconds then stops. Do I simply need to replace screen or is there another problem with power?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Not that simple! Yes you do need a new display, but you need to troubleshoot the logic board as well as you clearly have a deeper issue.
Consider the costs and your skills. If you don’t have the knowledge to read a schematic and using the common test tools as well as access to the components and tools to replace them it might be better to seek out someone who does.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lucky7 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 8
今までの合計 18
