Spilled water - used heater to dry - back panel cracking sound
I wanted to ask maybe you guys have an idea of what's going on.
I accidentally spilled less than a cups worth of sparkling water onto my computer, immediately turned it off, put it upside down and dryed it. For a bit less than an hour, I pointed a heater towards the keyboard, I put the temperature to more or less imitate the chassis getting hot under a huge load, or working outside in a hot environment.
The laptop still works fine, diag showed no errors, hopefully no corrosion, but after this, the sound appeared when pressing the left side bottom. It's driving my OCD, so I was wondering, Could the heater have caused it? I should probably have it checked out? I looked at the teardowns, and there doesn't seem to be anything that might be impacted.
Opinion appreciated, thank you!
Update (01/14/24)
Update (01/14/24)
Ok thanks, is it better now? Took pics from all sides
この質問は役に立ちましたか?
