メインコンテンツにスキップ
The Nokia 3310, released in 2000, is known for being incredibly durable.
26回答 すべてを表示
Why wont the nokia 3310 turn on after inserting lithium ion battery
I recently found an old Nokia 3310 and charged it. later it made some beeping sound that was about it needing a simcard. So i went and got one but just about when i got a simcard for it, it just died. didnt even get a chance to insert the simcard. i thought that the battery was completely dead so i bought a new one. This one was a lithium ion one. So i replaced the old battery with the new lithium one and began to charge it again. BUT. the strange thing was that it wouldnt turn on at all and somehow it discharged the battery when it was inside the phone. Why wont it turn on?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,Lore here.
It’s possible that the battery is not the issue. Here are some troubleshooting steps you can try to get your Nokia 3310 up and running again:
  1. Remove the battery and leave it out for 10-15 minutes. Then insert it back and turn on your phone. This can help reset the phone’s internal system and resolve any temporary issues.
  2. Charge the phone for at least 10-20 minutes before using it again. It’s possible that the battery was too low to power on the phone. If the phone still doesn’t turn on after charging, try using a different charger or cable.
  3. Perform a factory reset. After trying the previous operations, if your phone is slow or still doesn’t work, you can perform a factory default setting. This will result in all settings and configurations you’ve made on your phone being deleted.
  4. Take your phone to a repair shop or contact Nokia support. If none of the above steps work, it’s possible that there is a hardware issue with your phone. A professional repair shop or Nokia support can help diagnose and fix the issue.
I hope this helps you get your Nokia 3310 up and running again!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Alright. Thanks a lot. il definitely try them out
さんによる
コメントを追加
回答を追加する
The OOF さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 76
今までの合計 312
