メインコンテンツにスキップ
モデル番号A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5もしくは3.8 GHz Core i5もしくは4.2 GHz Core i7 Kaby Lakeプロセッサ (ID iMac18,3) / Retina 5Kディスプレイ。システムは類似しているため、修理ガイドについては旧モデルのiMac Intel 27インチ Retina 5Kディスプレイ (Late 2014 & 2015) を参照してください。
294回答 すべてを表示
Black screen after hard drive replacement
Hi,
I replaced the HHD to an SDD following the instructions on ifixit. Before gluing the screen with new stripes, I tested the devices by turning it on. Everything worked and I was able to re-install the macOS. So far so good.
Next, I used the stripes to finalize the process. It seems, that something got wrong during that step: my screen is black now.
So, I re-opened the iMac again and checked, whether I forgot to connect a cable or damaged anything in course of the process. Didn‘t find any hints, though.
Next, I connected the two cables, put the display back (w/o the stripes) and started the device. I am able to see some content on the screen, but it‘s very dark.
=> My assumption is, that the backlight is not working. Maybe I damaged the cable or even more. Would you agree?
I would like to start with replacing the cable. Question: which one (of the two)?
Thanks in advance.
Update (02/03/24)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Referencing this guide iMac 27インチ 2017 ディスプレイの交換
Jump to Step 19 this cable is the power cable and Step 20 is the data cable.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Hi,
Apology for the rather late reply.
Thank you for this hint. This is helpful.
Would the recommendation be to rather trying to replace the power cable first?
Thanks in advance!
さんによる
@eugen59161 - Let’s get a good set of images of your power cables logic board connector to make sure it’s OK first as well as the cable connector end as well.
さんによる
@danj, certainly.
I updated the question and added the images.
Btw: I reconnected everything once again - unfortunately no improvement
MANY thanks in advance!!!
さんによる
@eugen59161 - Well the cables and connectors look good! So that’s not the issue. That only leaves one possibility, could you have flipped the displaces data cable plugging it in backwards? While the backlight and logic uses the the power cable there are a few lines that can get damaged within the data cable if you reverse the cable plugging it in the wrong way and then powering the system.
さんによる
Hm, that‘s a very good question. To be very certain with my answer, I actually opened and closed the display again. While doing so, I noticed that there is almost no chance I connected incorrectly. I.e, I am 99,9% certain that I connected correctly.
さんによる
コメントを追加
回答を追加する
Eugen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 73
