Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11.
This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
@davidclaydon I could also use some clarification on the exact problem since the title says the triggers activate, but your post says the joysticks activate.
Did you replace the joystick cap (the plastic bit the pops on the stem of the joystick)? Or the joystick itself (which would have required soldering)?
My apologies I wrote this on too little energy. I entire replaced and soldered an entire new joystick on. When I would press the joystick down it would active the Left and Right triggers 100%
Which joystick did you replace?
Alisha C さんによる
@flannelist The upper one
David Claydon さんによる
Alisha C さんによる
David Claydon さんによる
