メインコンテンツにスキップ
2.26 or 2.4 GHz / White plastic unibody enclosure
No Signs Of Life when plugged in- Unknown Cause, How to troubleshoot
I recenly got a a1342 late 2009 to 2010 and tried to plug it in with the included 60W power cable in the shape of a line and T. Nothing happened so I used a known working 60W charger in the shape of a line. I left it on charge for a bit and nothing is happening not even a light on the charger or a beep and i'm unsure on what to do next. Please help me!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I would inspect he MagSafe connector contacts as well as make sure the socket area is clean of junk which can hold the surfaces apart.
The cord LED needs to light up, are you getting Amber or Green light at all while holding the cord firmly into the socket? I would see if replacing the MacBook Unibody (A1342) MagSafe DC-In Board as often the insulator warps stopping the connection.
If that fails that aims us to a deeper logic board issue.
Replace a broken or damaged MagSafe DC-in board for your Model A1342 MacBook Unibody with this part. This assembly connects the AC wall adapter power to the logic board and is compatible with all Unibody (Model A1342) 13" MacBooks.の画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
The cord led is not lighting up and I know the cable works as I just used it on another device and it showed a led. I tried plugging it in after cleaning the port with 70% isopropyl alcohol on a Q tip on the pins and gunk beneath it though the cable is still not lighting up. What do you think I should do next?
さんによる
@legperson123 - replace the MagSafe port. Checkout the part I linked in my answer.
さんによる
コメントを追加
回答を追加する
Aussie Selo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 79
