メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Latitude D820は2006年3月28日に発売され、モデル番号PP04Xで識別されます。
My computer won't turn on
When I press the power button on the computer, the computer does not turn on, but the control lights next to the power button turn on and blink for a minute and then the computer turns off
LED 1 is lit continuously
LED 2 and 3 are on alternately
Attached is a picture
I would appreciate an answer
Thanks in advance
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Hi @elchanan1
A blinking caps lock and scroll lock light indicates a motherboard problem (CPU?).
Try removing the ram and start the laptop. If there are no error beeps heard then the motherboard is faulty as ram is checked early on in POST (power on self test) so it hasn't even got that far when starting
Has the laptop been dropped or gotten wet at all?
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
The computer did not fall or get wet
さんによる 共有
@elchanan1
I can only suggest that you download the schematic for the motherboard and check the voltages - see p.47 (CPU voltage) and p.48
さんによる 共有
コメントを追加
Have you tried another outlet? Or cable?
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
I tried another cable and it didn't help
The same fault remained
さんによる 共有
There may be a power failure. It may be the motherboard or battery, both, or something else.
さんによる 共有
Could also be a corrupted OS.
さんによる 共有
I tried turning on the computer only when it is plugged in without a battery and still the same error remains
And it's not an operating system because the bios still doesn't come up
さんによる 共有
Have you tried to check the power button? It may be a problem with the case's power button
さんによる 共有
1以上のコメントを表示
コメントを追加
My first thoughts:
https://www.dell.com/support/kbdoc/en-us...
Have you tried reseating the ram and swapping out modules one at a time?
Bad ram is so often the culprit.
Removing one module at a time, trying only one module, and then swapping them around after reseating them
might fix the issue or at least change your LED indicators.
Have you checked all your internal component connections yet (hdd, videocard, modem, CPU, ODD, etc.)?
It's remotely possible you might need to replace the cooling paste on your CPU after so many years.
If it's cheap and easy, I would replace the BIOS battery just for good measure.
Good luck!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I already tried everything except thermal paste, but thermal paste should not cause such a malfunction
さんによる 共有
コメントを追加
回答を追加する
Elchanan Blumenfeld さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 32
今までの合計 627
