メインコンテンツにスキップ
Appleのメインストリームとなる2020年iPhoneモデルは10月23日に発売されました。6.1インチOLEDディスプレイ、デュアル12MPカメラシステムと5色のカラーバリエーションがあります。iPhone 11の後継モデル。
165回答 すべてを表示
Restart every 3 minutes after water
Hello,
i am right now in holidays and my iPhone 12 got a little bit wet. After that it restarts every 3 minutes. So i looked it up and my panic report told me thermalmonitord. How can i arrange now what sensor is faulty? Also is there like a savemode so if i‘m home i could take a backup?
Greetings
Update (11/27/23)
{"bug_type":"210","timestamp":"2023-11-27 12:24:34.00 +0500","os_version":"iPhone OS 16.7.2 (20H115)","roots_installed":0,"incident_id":"E97F1F8E-97D5-4524-9CA0-BAE7D1C681B7"}
"build" : "iPhone OS 16.7.2 (20H115)",
"product" : "iPhone13,2",
"socId" : "8101",
"socRevision" : "11",
"incident" : "E97F1F8E-97D5-4524-9CA0-BAE7D1C681B7",
"crashReporterKey" : "18855d0161bc64382b6d3c908e65521f32e0b13e",
"kernel" : "Darwin Kernel Version 22.6.0: Wed Oct 4 21:55:46 PDT 2023; root:xnu-8796.142.1.701.11~1\/RELEASE_ARM64_T8101",
"date" : "2023-11-27 12:24:34.99 +0500",
"panicString" : "panic(cpu 2 caller 0xfffffff02c62b8e8): userspace watchdog timeout: no successful checkins from thermalmonitord\nservice returned not alive with context : is_alive_func returned unhealthy : current 5fffffffff, mask 3fffffffff, expected 3fffffffff. SD: 1 BC: 1 RC: 0 BS: 1, Missing sensor(s): Prs0 \nservice: backboardd, total successful checkins in 194 seconds: 19, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 169 seconds: 17, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins in 194 seconds: 18, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 194 seconds: 19, last successful checkin: 0 seconds ago\nservice: thermalmonitord, no successful checkins in 194 seconds\nservice: runningboardd, total successful checkins in 194 seconds: 19, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins in 194 seconds: 18, last successful checkin: 0 seconds ago\nservice: configd, total successful checkins in 194 seconds: 18, last successful checkin: 0 seconds\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 20H115\nKernel version: Darwin Kernel Version 22.6.0: Wed Oct 4 21:55:46 PDT 2023; root:xnu-8796.142.1.701.11~1\/RELEASE_ARM64_T8101\nFileset Kernelcache UUID: C5D2A5F46EB1E5A63AF8FDE73B4AD5E9\nKernel UUID: 510BBA43-3466-3323-88BD-6B231BB89712\nBoot session UUID: E97F1F8E-97D5-4524-9CA0-BAE7D1C681B7\niBoot version: iBoot-8422.142.2.700.1\nsecure boot?: YES\nroots installed: 0\nPaniclog version: 14\nKernelCache slide: 0x0000000023fa4000\nKernelCache base: 0xfffffff02afa8000\nKernel slide: 0x0000000023fac000\nKernel text base: 0xfffffff02afb0000\nKernel text exec slide: 0x0000000024d14000\nKernel
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Bernie,
There's generally more information associated with the thermalmonitord failure. It will help if you post the first page of your panic log so we can see which particular sensor is missing, because that's what you're looking for. There's more information on the subject in @flannelist's excellent kernel panic wiki page.
iPhone Kernel Panics - iFixit
Using that information you should be able to pin down which part needs to be replaced to fix the issue you're seeing based on which sensor is missing. My personal guess is that you're going to find that you're having an issue with the lightning port flex cable because that's the part that's most easily exposed to liquid submersion. Of course, if you've got any cracks on the front or back of the phone then all bets are off.
Update (11/27/23)
Yep, here's the smoking gun right there.
PRS0 is the barometric pressure sensor located on the lightning port flex cable assembly. It's connected to the barometric vent, so any failure in the seal of that vent means the sensor gets exposed to water and - as you found out - it fails. Here's the part you'll need to replace to fix the sensor.
iPhone 12/12 Pro Lightning Connector Assembly
Note that it comes in different colors in order for the inside of the port to match the color of your phone. That's strictly a cosmetic issue though; in practice you can put any color you want in there. You can buy it here on iFixit and support their repair efforts, but you can also find in on the major sites like Amazon, eBay and AliExpress among others.
Unfortunately, iFixit doesn't have a guide for your repair, but there's a Spanish site called Nadie Me Llama Gallina that has just what you need. This guide will step you through the replacement from beginning to end.
Manuales / Apple iPhone 12 / Auxiliary board
Don't forget to pick up a sheet of precut adhesive to secure the screen back on once your repair is complete; although it won't restore the IP68 rating, it will help keep water out should it get accidentally exposed. To be honest, I usually buy a couple; they're unfortunately all too easy to mess up - if you don't get them on exactly right the first time there's no second chance.
That should do it for you; once you've replaced that part your phone should be back in business! Good luck with it, and let us know how it goes.
iPhone 12/12 Pro Lightning Connector Assemblyの画像
製品
$79.99
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
So i updated it could you tell me which sensor it is?
Greetings
さんによる
コメントを追加
回答を追加する
Bernie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 80
