メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
New LCD Install - No Display
I've got a Mid-2009 Macbook Pro 13, and I just installed a new LCD after accidentally cracking the old one. Before the install, the old LCD would still show a white screen, and I could display the screen on an external monitor. After the replacement, the NEW LCD would simply remain blank when I turned on the computer (I can still display on an external monitor). I swapped the LCDs out again, and the old (cracked) one will still light up as it did before. I then reinstalled the new one, yet it still does not display. I've checked the connections on the logic board, and I don't believe I have an problems there, and since I can display and operate the computer using and external monitor, I don't think the Logic Board itself is damages either.
Any ideas what might be wrong? Do I need to do anything special to make the LCD register with the computer (wouldn't think I would need to). I'm thinking the NEW LCD was DOA and that I need to send it back, but thought I'd reach out first.
Any suggestions are welcome.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
it should be the same number at back of your original led screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Yea that screen was DOA -if you haven't already contact the vendor for a replacement.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Josh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 577
