メインコンテンツにスキップ
2014年4月のアップデートによりアップルの13インチMacBook Airはデュアルコアi5またはi7プロセッサーの更新とわずかなバッテリー性能の向上がされました。
Internal SSD storage not appearing in disk utility
I have replaced my SSD that came with my Mac a bit ago, because it wasn’t appearing on my disk utility on recovery mode, however, even after replacing it, it refuses to appear, I’m using Big Sur, and the SSD has already been formatted, and disk utility is on “show all”.
UPDATE: for some reason it appeared once i switched over to high sierra (dispite me already doing that), the SSD appeared on my Mac, but did not appear in Big Sur, so ill be on high sierra for a bit, thank you Dan for your answer :D
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Yep! A very common issue! Your hitting the HFS+ Vs APFS problem! The macOS you are using is newer than what Apple offers you via Internet Recovery! To compound this you maybe using the wrong SSD.
Using a second Mac (or reinstall the original drive if you can get it working) prep up a bootable OS installer USB thumb drive with Big Sur.
Start off by formatting the thumb drive with a GUID Mac format. Then download the installer from here How to download and install macOS then follow this to guide Create a bootable installer for macOS.
Now use it to boot up your system you should now be able to see the internal drive using Disk Utility from the thumb drive.
If not you’ll need to dig into why. Are use using the correct SSD? Are you trying to install a M.2 SSD via an adapter? Is the system damaged in some way?
If you do see it again format it and install the OS that should do it!
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I have been using a bootable drive the entire time, I’ve tried multiple versions of macOS, and still the internal drive never shows up, it should work because the SSD is from another mac, and from what I can tell there’s no visible damage.
さんによる
@jaidenquince What Mac was the SSD pulled out of?
さんによる
@thequacker it’s been pulled out of a MacBook Air 2014 11’, model number was: A1465.
さんによる
Can you give us the maker and model info so we can check it out.
さんによる
コメントを追加
回答を追加する
JaidenLE さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 201
