Not all the bulbs light up
I have 423 addressable LEDS that I soldered (first time) together. I turned it on and everything worked. I then put the strip into the location I wanted and now only the first 50sih work. I have looked at all my solder location and everything seems fine. I do have a multimeter to help figure out where my problem is, but I don't know which function/how to use it. Any help will be amazing.
2 件のコメント
@mitchellb75424 How are you powering the LEDs? If using an external power supply/LED Driver, what are its specifications?
Andrew S さんによる
The LEDS are powered via external source, 5V 2A. I know that since I had to re-solder some wires, I am sure that is the issue but as I don't know which ones are bad, I was hoping there was a way to test via multimeter.
Mitchell B さんによる
