メインコンテンツにスキップ
モデル番号A1706/EMC 3017ー2016年11月発売。この13インチのMac Book ProはOLED Touch Bar搭載です。デュアルコア"Skylake" Intel Core i5 CPUと4つのThunderbolt 3ポートが特徴です。
241回答 すべてを表示
MacBook Pro with touchbar has 10cm line on the right
I have a 2016 mac book pro with touchbar
and it has a 10 line on the right side now I don't know wether it's hardware or software and is their somewhere in Australia that I can get a board from model is a1706
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Screen damage is very likely. This problem will be resolved if the screen is replaced, there is a possibility that it will fall or be crushed by another object
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I was going to do the screen anyway and while I am in their the battery will be replaced. And anything else that’s suspect looking
さんによる
It's a good idea to replace it in a place that looks official because this kind of analysis is handled quite easily
さんによる
@yusufdwi010199 - Is correct your display is damaged! Here's the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here's the guide to put it on MacBook Pro 13インチ Touch Bar Late 2016のディスプレイアセンブリーの交換
And yes your battery is likely near the end of its useful life. I would install this gem of an App CoconutBattery it will allow you to see things better than what Apple offers in its battery health function. Post a snapshot of it so we can see where you are now
In any case again here's the needed part MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery and the guide to put it in MacBook Pro 13インチ Touch Bar Late 2016 バッテリーの交換
Given the costs of needed both you might want to look at getting a used newer system.
As for someone to do the repair if its too daunting for you, I would give Paul Daniels a try PLDaniels Repairs
さんによる
コメントを追加
回答を追加する
josh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 54
