Is the audio in/audio out port replaceable on this model?
We have scratchy and bad audio, quality using various cables, with our MacBook Pro audio port. Is this part user replaceable?
Best,
Mark F
この質問は役に立ちましたか?
Best,
Mark F
この質問は役に立ちましたか?
Well… not really😖
I’ve marked the port here, it’s a custom part sadly.
Did you try cleaning? Try using a oil free spray cleaner.
このアンサーは役に立ちましたか?
I kind of figured it was attached to the motherboard. After posting my question, I remembered I had some electrical contact cleaner. I gave it a gentle pod with a Q-tip, that was given a haircut, so as not to leave a bunch of fluff in the port. If that doesn’t work, I will convince my better half that she should use the USB to audio adapter.
Have a great day and thank you for your reply.
Best,
Mark F
@markf75304 if you’re set don’t forget to accept the answer - Thanks!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 28
