How do I replace the Keyboard backlight on a2159 MacBook Pro
I can’t find a video on it.
Are you sure you need a need keyboard backlight?
Finding the backlight plate for this series is not easy! Apple reduced its service parts at this point you’ll need to find a parts junker to reuse it or if you has a liquid spill I think you’ll find just getting the full uppercase assembly MacBook Pro 13" (A2159, 2019) Upper Case Assembly
このアンサーは役に立ちましたか?
I mean the cable
But either way I found all of the parts for it, and it’s not that expensive
@ola48955 - Well that’s a different kettle of fish😊
Here’s the needed part Keyboard Flex Cable
The process is the same as taking out the logic board following this guide MacBook Pro 13" Touch Bar 2019 Logic board Replacement
A2179 keyboard light is not detachable , All butterfly keyboard light is embodied with the keyboard which mean you have to change the keyboard
このアンサーは役に立ちましたか?
No I mean the cable
its a flex besie the battery
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 83
