メインコンテンツにスキップ
2015年10月13日に発売。A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 プロセッサ。
96回答 すべてを表示
iMac Airport driver causing CPU panics, antenna looks rusted?
As you can see in the photo, the Wifi antenna looks discolored, almost rusted. The rest of the iMac looks fine, just the normal dust. The Wifi works a bit, will connect to 2.4 but says the password is wrong on 5Ghz networks (it's not). The iMac will restart randomly with an Airport driver as likely suspect. I'm thinking of removing the board and just using a USB dongle but was wondering if anyone had any thoughts on what's going on here. Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I would replace the antenna unit as it’s possible it’s shorting out.
As far as a USB dongle I think you’ll have a hard time finding one. You’ll need an Ethernet to WiFi bridge to connect via the systems Ethernet port. Thaway you can get the full data rate.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
maccentric さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 19
