メインコンテンツにスキップ
2018年9月21日に発売されました。モデル番号A2097, A2098、GSM もしくはCDMA / eSIM もしくはナノSIM / 64, 256、512 GB / シルバー、ゴールド、スペースグレイ。(正しい発音は"iPhone 10 S.")
398回答 すべてを表示
Tengo problemas con panic full
{"bug_type":"210","timestamp":"2023-10-09 00:30:57.00 -0300","os_version":"iPhone OS 16.5 (20F66)","roots_installed":0,"incident_id":"E1359F80-E32C-4AD5-B086-5F8B073B35E0"}
"build" : "iPhone OS 16.5 (20F66)",
"product" : "iPhone11,2",
"socId" : "8020",
"socRevision" : "11",
"incident" : "E1359F80-E32C-4AD5-B086-5F8B073B35E0",
"crashReporterKey" : "f2aa523d642a578ea63139d414196d9bb46960f9",
"kernel" : "Darwin Kernel Version 22.5.0: Mon Apr 24 21:10:51 PDT 2023; root:xnu-8796.122.4~1\/RELEASE_ARM64_T8020",
"date" : "2023-10-09 00:30:57.74 -0300",
"panicString" : "panic(cpu 0 caller 0xfffffff01441c598): userspace watchdog timeout: no successful checkins from thermalmonitord in 180 seconds\nservice returned not alive with context : is_alive_func returned unhealthy : current 7fffffffffffe, mask 37ffffffffdff, expected 37ffffffffdff. SD: 0 BC: 1 RC: 0 BS: 2, Missing sensor(s): TG0B \nservice: backboardd, total successful checkins in 1073 seconds: 106, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 1032 seconds: 104, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins in 1073 seconds: 105, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 1073 seconds: 106, last successful checkin: 0 seconds ago\nservice: thermalmonitord, total successful checkins in 1073 seconds: 73, last successful checkin: 180 seconds ago\nservice: runningboardd, total successful checkins in 1073 seconds: 106, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins in 1073 seconds: 105, last successful checkin: 0 seconds ago\nservice: con\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 20F66\nKernel version: Darwin Kernel Version 22.5.0: Mon Apr 24 21:10:51 PDT 2023; root:xnu-8796.122.4~1\/RELEASE_ARM64_T8020\nFileset Kernelcache UUID: 1AF7443734C73F52E3C5898E71DF2AA1\nKernel UUID: 9ED7ED28-9213-39A2-8130-0B56D42D04EA\nBoot session UUID: E1359F80-E32C-4AD5-B086-5F8B073B35E0\niBoot version: iBoot-8422.120.66\nsecure boot?: YES\nroots installed: 0\nPaniclog version: 14\n
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi David,
I took the liberty of trimming the size of your panic log, as we really only need the first page of it to find the problem. In your case the magic clue is right here.
If you check @flannelist's excellent Wiki article on kernel panics, you'll find that the TG0B sensor is a battery sensor, probably for temperature. Essentially, the little circuit board mounted on the battery that's called the BMS or Battery Management System has failed. In order to replace it, you'll need to replace the battery since all batteries come with the BMS already installed.
So the short story is, replace the battery and you should be fine.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
DAVID Cardozo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 41
