Pioneer VSX-421-K not turn on
Hi everyone. I have this AV reciever Pioneer VSX-421-K. I didn't use it long time and last day I decided to power it but not working.
When i push the power button, nothing happened. I tried to reset it with (BAND + STAND BY/POWER) buttons but nothing going on, also tried with (ALC/STANDART SURROUND + STAND BY/POWER), the result is same. Nothing. After pushing at the same time (ADVANCED SURROUND + STAND BY/POWER) relay is clicked and device turned on but for only 2 seconds and turned off again.
I opened the device to check the main fuse and it's OK. I checked transformer also and it's working. After this i checked the Amp board transistors, and i found two broken on front right channel and replaced them, but problem with turning on is same.
There is nothing hooked up to reciever like TV, Plastation or speakers.
Update (09/30/23)
Yeah, sorry for that there is photos. Replaced transistors is for front right channel (2sd2390 and 2sb1560)
And that is other visible pcb board
@alperbeysim let us know which transistor you replaced. Post some pictures of the boards so we can see what you see. That way we can hopefully identify some traces or components that may have been responsible for the failed transistors. iFixitでの質問に画像を追加する方法
oldturkey03 さんによる
@alperbeysim did you take these pictures during your repair? I noticed there are IC's that are not (or only partially) connected. BTW good pictures. Thank you for those.
oldturkey03 さんによる
@alperbeysim there is a challenge coming up and I have chosen your question for this. It may get a bit confusing and I do apologize for this. I promise that we are working on a solution on the issue with your Pioneer
@kingofspades try your AI on here. Let's see if you can use it in a responsible, knowledge and skill augmenting way.
oldturkey03 さんによる
@alperbeysim I would suggest you check the other transistors as well and make sure they are properly soldered on. It uses the same amp board as the 521 and 821
oldturkey03 さんによる
@oldturkey03 I checked all of transistors on other channels and they are ok. The pictures are the during the replacement. Thanks for the gesture, I'd appreciate it if we could fix it
Алпер Бейсим さんによる
3件以上のコメントを表示
