Could ghost touch be attributed to a faulty battery?
iPhone X is functioning on its own. Is ghost touch a faulty screen / digitizer problem or can it be related to an old battery?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yeah, that sounds like it's either a screen problem, or maybe water damage. However, you might as well check your battery's health (Settings --> Battery --> Battery Health) because if you're gonna open up your phone to replace the screen, that would be a good time to replace your battery if necessary.
このアンサーは役に立ちましたか?
Ok, thank you. My friend contacted Apple and they said battery, but I felt it would be screen. Thanks for the feedback.
@chadwhick7 I don't know who your friend talked to at Apple, but they were feeding them some grade-A BS. There is nothing in the battery that has any kind of direct connection or effect on the touch screen/digitizer.
100% that's a screen problem and needs a replacement.
@dadibrokeit yeah, that was my feeling too after reading about it online. It kind of sucks getting that kind of info second hand. I ordered a screen and battery and figured the battery is probably old anyhow.
@chadwhick7 Sounds like a good plan. You're absolutely right about the age of the battery; as long as you're going to have it open anyway you might as well put a new battery in as well; that'll give you some extra time before you have to open it up again.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 73
