メインコンテンツにスキップ
2020年にAppleより発売されたトップラインのスマートフォンです。iPhone 12 Pro Maxは11月13日に発売されました。6.7インチ OLEDディスプレイとLiDARを搭載したトリプルリアカメラシステム、5Gネットワーク接続が可能です。iPhone 11 Pro Maxの継続モデルです。
117回答 すべてを表示
Cell error and reboots on own
I keep losing signal and it grey’s out the WiFi , Bluetooth, and cell signal is searching… apple said it was hardware issue and wants $500 to repair it. When this is the 4th time I’ve had the issue and they swapped me out for a new phone. Battery life is now 90% capacity. I’m not able to micro solder the antenna or know what actually went bad .. anyone else have this issue and know what went bad?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
These are fairly common issues with the 12 pro max and although they did replace the device in the past, they never actually fixed the problem.
This model, like previous ones, has a stacked motherboard. Meaning there's two boards stacked on top of each other and soldered around the edges. Those solder joints can become weak or break over time. Or in other cases the chip(s) themselves will have issues. This video will explain it and show how the repair is done. But this is not something you can DIY. https://www.youtube.com/watch?v=oAeOZeXR...
If you're in the states, you can mail your device into VCC and Jesse can repair it. I've personally sent him a handful of board repairs from my shop. He has excellent customer service and I highly recommend him.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bryant Mckinney さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 46
