メインコンテンツにスキップ
2018年7月に発売された、モデル番号{A1989 / EMC3214}のMacBook Pro13インチモデルにはクアッドコアi5と i7 を搭載しており、グラフィックにIntel Iris Plusが統合されています。
208回答 すべてを表示
Will MBP still work if Touch Bar is disconnected?
My MBP's Touch Bar started doing the blinking/flashing thing about 17 months ago. It got to the point where sometimes it would even stay off. I remapped the most essential functions to the physical keyboard, so not having a working Touch Bar didn't bother me too much. However, putting the MBP to sleep when the Touch Bar was off would cause the MBP to crash upon wake, at which point the Touch Bar would be on again. Strangely enough, restarting or shutting down did not do this - the Touch Bar stayed off. So I managed to keep the Touch Bar off for over a year by never putting my MBP to sleep - it was either on, or shut down.
Eventually, after a little over a year, the MBP randomly restarted itself in the middle of a sesson, and the Touch Bar turned on again. It worked fine for about 5 weeks, but now it's blinking/flashing again, and rapidly getting worse. Anyway, to avoid a costly repair, would it be possible just to leave the Touch Bar disconnected from the logic board? Or would it render the MBP unusable? Or maybe I can just let it blink itself to death, as long and annoying as the process will be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Good question! Sadly I’m not sure😞 I’ve always replaced them which is a pain!
A good Mac repair person should be able to replace the TouchBar if that is the issue it’s Also possible the issue is the driver logic which is even easier to get to and replace but a bit more expensive a part.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thanks for the reply! Unfortunately, according to another answer given in this forum, it is not possible to source a Touch Bar for the 2018 MBP, the only repair available is a full upper case replacement. If the repair was just a Touch Bar replacement, I'd probably do it, especially since I don't know if I trust myself to open up the MBP and disconnect the Touch Bar, so I'd probably pay someone even just to do that, if I knew it would work.
さんによる
@jcchang - Here's the part for your system Touch Bar for MacBook Pro 13 Inch A1706 2016-2017 A1989 2018-2019 That is what I've used
さんによる
Oh cool, I only looked at the part available here. Thanks!
さんによる
A bit late..but I was informed by an apple authorised service person that the error is probably on the logic board or on the upper case....and that one of these needs to be replaced. He did not say anything about just replacing the touch bar itself. But maybe that only reflects how Apple works - i.e. even if it's only the touch bar that is broken they do not replace that alone but the whole cover. I would like to know how disconnect the Touch Bar physically - and if that would have any unwanted effects (will the start button work).
さんによる
コメントを追加
回答を追加する
jcchang さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 29
今までの合計 262
