メインコンテンツにスキップ
一般的にはパンツと呼ばれています。修理は、パタゴニアブランドのパンツの穴の補修からジッパーの交換まで。
Repair or replace hook of hook-and-webbing adjustable belt
Hi,
I bought the Patagonia Dirt Craft Bike Shorts last year. They have a built-in adjustable belt / waistband with a hook on the end that slots into one of a range of loops as per the photo attached (from the page). The hook part of this piece of metal has broken off (it's turned from a "6" to a "o") on both sides, each time after a wash cycle despite following the instructions to wash cold/warm and tumble dry low.
I'm looking to repair or replace the hook pieces without having to send it in to Patagonia (but I will if I have to.) I am pretty ignorant to how I'd go about it. Any ideas?
I don't think any kind of glue or adhesive would hold the broken hook arms to the hook base (turning the "o" to a "6"), but maybe I'm wrong. I'm not sure where I'd get another hook piece like this. And if so, I'm not sure how I'd attach it, given that the "o" part is secured inside the strap.
Thanks for your help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I think that is called a "G Hook", but I bet if you take it into a local haberdashery they'd be able to put you straight.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Brad Léo Hallam さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 17
今までの合計 235
