メインコンテンツにスキップ
Retina MacBook 2016からアップデートされたバージョンです。モデル番号はA1534(EMC3099)です。Turbo Boost使用時最大3.6GHzの最大1.4GHz Core i7の高速Kaby Lakeプロセッサ、最大50%高速のSSDを搭載し、最大2倍のメモリをサポートしています。
81回答 すべてを表示
Does not power on with USB-C Dock.
Hey guys the battery of my Macbook Retina 2017 is defect and won't charge anymore. I usually only use it connected to the power supply so it didn't matter to me much.
But now I bought myself a HDMI USB-C Dock with a 60W Power Delivery Port, but the MacBook won't turn on when I plug in the dock in between the only Thunderbolt Port the device has and the power supply.
The Dock works fine and charges when I plug it into my iPad Pro so the PD function is working. I also bought a 90W USB-C power supply which acts the same (works when plugged in directly but not when the dock is in between.
And I also bought a second dock, but the problem remains, it is like the MacBook does not allow to use the dock when the battery is defective ... any advice?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Is this an Apple certified dock? Some are USB-C only not Thunderbolt which is what you need here.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
You are right, it is just an USB-C Dock, but I haven't had problems with my iPad with that one. Is this a specific requirement for that MacBook? Since I know of many friends that also use cheaper USB-C Dock for their MacBooks Pro. But it wasn't one from the original apple store, one I tried was from Am*zon the other one from a retail store.
さんによる
Apple didn’t offer Thunderbolt functionality in the first USB-C connectorised iPads. So that explains different reaction.
さんによる
Since my iPad is a iPad Pro, 11" (3. Generation) it is equipped with a Thunderbolt 3 Port, so it must be something else.
さんによる
@marcogotthardt - Then the USB-C port of your MacBook is damaged. As you also stated it was having issues with power connections. Here’s the guide to replace it Retina MacBook 2017 USB-Cポートの交換
さんによる
Ok, thanks for your help, I didn't knew that a port can be so strangly defective. I would have guessed either it works or it doesn't, since the pins at A4+A9 aswell as B4+B9 work properly.
さんによる
コメントを追加
回答を追加する
Marco Gotthardt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 47
