Standby light flashes three times
Lg 55cs6. When turning on TV the standby light now flashes three times, I'm certain up to now it would just light once before TV came on. Do I have a potential problem?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@cjl44778 double check your model number. Is it something like OLED55CS6LA? Okay, so it blinks 3 times but you are not telling us if it comes on or not.
If it blinks but does not turn on, the first suspect will be the power board.
Consider this normal behavior for the "C" series" if it does start up. It is not an issue.
このアンサーは役に立ちましたか?
Hello. Sorry yes that is the model number oled55CS6la. Yes it is turning on, this issue with flashing three times seemed to begin today after another weird thing, where a film had a loud electronic noise over normal sound and for some reason audio description was on as well, only on that channel. it stopped on its own but then I noticed the flashing light. TV only nine months old so I'm concerned a problem developing that could be sorted under warranty . If you think it's normal ,then all good?
@cjl44778 for as long as it all works, I Would not be concerned about it. LG does not yet (eventually they will with the help of AI) have blink codes that will let us know that things are going to fail eventually. For now, enjoy your TV. If something creeps up, let us know and we can always try and help you out.
過去 24時間: 2
過去 7 日: 4
過去 30 日: 26
今までの合計 175
