メインコンテンツにスキップ
モデル番号A1706/EMC 3017ー2016年11月発売。この13インチのMac Book ProはOLED Touch Bar搭載です。デュアルコア"Skylake" Intel Core i5 CPUと4つのThunderbolt 3ポートが特徴です。
241回答 すべてを表示
Logicboard inter-model year compatibility?
I wonder if It would work, to put a Logicboard from a 2018 MBP into a 2016 MBP. Is there any general rule of Logic-Board inter-compatibility between model years?
My biggest concern so far is the pairing to the T2-Chip.
Background: I have multiple 13"-MacBook-pros. All with Touchbar and 4 USB-C/TB-Ports, but they come from different years (2016 to 2018) and some have hardware issues or just look very worn. Thus I would like to transplant Logic-Boards from worn/defective Macbooks into other less worn and well working MacBook bodies.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sorry, it’s not so simple!
The 2016 and 2017 share common heritage, Apple did enough tweaking in the follow up designs to prevent using 2018 and newer. While not definitive here’s how one can often see what is compatible across. Look at EveryMac - MacBook Pro list so for an example we can see the Late 2013 and 2014 share the same base Model ID MacBookPro11.x where x is the sub version
Apple didn’t like it we figured out their system and from 2016 onward we don’t have a clean means to tell what is interchangeable here we need to depend on parts houses to give us a clue! Often they make look the same but are not signal compatible! This gets into TrueTone in this case.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Schnubdiwubb さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 74
