メインコンテンツにスキップ
2018年9月21日発売。モデル番号A1921, A2103, A2104、GSM もしくはCDMA / eSIM もしくはナノSIM /64, 256,もしくは512 GB/ シルバー、ゴールド、スペースグレイ(正しい発音は"iPhone 10 S Max")
381回答 すべてを表示
Auto Restarting every 3 minutes
Hello Guys, The device was physically damaged and had a original display replacement. But the device has still the same 3 minute reboot. Tried all the software troubleshooting and also tried removing all the flex except battery and display to find the sensor but couldn't resolve the issue.
This is the panic log.  Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
@oldturkey03 is exactly right, the PRS0 sensor is a pressure sensor that works with the barometric vent and is located on the charging port assembly flex cable. So yeah, in addition to the new screen you're going to need that lightning port assembly replaced as well.
If you're interested in learning more about those kernel panics that are rebooting the phone, Alisha ( @flannelist ) has written an excellent wiki article on the subject; it point you directly to the charging port after finding that missing sensor: PRS0 line.
iPhone Kernel Panics - iFixit
Sorry to say, iFixit hasn't gotten around to creating a lightning port replacement guide for your phone yet, but I did find a good one on a Spanish side called Nadie Me Llama Gallina, or Nobody Calls Me Chicken. Use it with the Chrome web browser's automatic translation and you won't have any trouble; just note that "battery" gets translated as "drums" and "flex cable" come across as "tablecloth"; other than that it's straight forward and easy to follow.
Manuales / Apple iPhone Xs Max / Flex with load connector and lower microphone - Nadie Me Llama Gallina
The parts themselves you can get anywhere; I usually start with Amazon, eBay and AliExpress depending on how cheap I am vs. how fast I want it. Of course, you can support iFixit's repair efforts by purchasing the part right here; don't forget to pick up a sheet or two of the precut adhesive for sealing the screen back up when you're done.
iPhone XS Max Lightning Connector Assembly
iPhone XS Max Lightning Connector Assemblyの画像
製品
$24.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
24.A Monish.M さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 25
今までの合計 130
