Which type of fuse for a microwave?
I have a 1980s Samsung microwave with a blown internal fuse. Trouble is, by looks alone it could be a slow-blow or quick-blow type. Obviously, I can try both, as fuses are cheap. However, does anyone know which type it should be?
(I can imagine the stop-start nature of low power settings could result in current surges that might cause a quick-blow fuse to rupture - hence a slow-blow is specified. However, IF the circuit demands a quick-blow, I do not want to compromise our safety by using the wrong type.)
4 件のコメント
Hi @cycleboy1957,
What is the model number of the oven?
jayeff さんによる
RE-553T, Jan 1985 model
Cycleboy1957 さんによる
Thanks for the tip about the fuse code labels. I didn't know that before.
The label next to the fuse holder and the circuit diagram just say '7A'. Neither makes any mention of quick or slow blow.
The fuse has '250 VOLT' on one cap and 'BUSSMD^7' on the other, though the'^' might be an incomplete capital A. It sounds as though an ordinary 7A fuse ought to be acceptable.
The circuit diagram shows a shunt resistor across the capacitor. It's been disconnected for months now, so is surely fully discharged by now. I'm not sure if the shunt is internal to the capacitor or an external component, but I will check and be careful.
Cycleboy1957 さんによる
Thanks for the tip about the fuse code labels. I didn't know that before. And thanks for searching your sources.
Cycleboy1957 さんによる
